1. Technical Specs Overview
CategorySpecificationDetails
PerformanceThrust160 lbs (Adjustable via controller)
Maximum Power20 kW
Flight Time (2.6 kWh)20 – 40 mins
Flight Time (4.8 kWh)55 – 80 mins
Recharge Time2.5 - 4.5hrs
Stander Operating Temperature Range-10 - 40c
WeightParamotor Unit29 lbs
Battery (2.6 kWh)25.8 lbs
Battery (4.8 kWh)49.0 lbs
Ready-to-Fly Total54.1 – 78.4 lbs
ConstructionMaterials6061 T6 / 7075 T6 Aluminum, Grade 5 Titanium, Carbon Fiber Spars
Propeller140 cm Carbon Fiber (Bi-blade or Tri-blade)
NettingDyneema (5x stronger than steel)
HardwareMotorOpenPPG v2.5 25 kW high-efficiency brushless motor
Motor ControllerField-Oriented Control (FOC) High-powered, weatherproof, CAN bus controlled
Throttle ControllerBuilt-in altimeter, haptic feedback, EICAS
Battery PackCustom designed for paramotors with built-in Bluetooth BMS and CAN bus for communications. Using high energy density MNC cells.
WarrantyCoverage12 months - 300 hours
