Technical Specifications
Technical Specs Overview
CategorySpecificationDetails
PerformanceThrust160 lbs (Adjustable via controller)
Maximum Power20 kW
Flight Time (2.6 kWh)20 – 40 mins
Flight Time (4.8 kWh)55 – 80 mins
Recharge Time2.5 - 4.5hrs
Standard Operating Temperature Range-10 - 40°C
WeightParamotor Unit29 lbs
Battery (2.6 kWh)25.8 lbs
Battery (4.8 kWh)49.0 lbs
Ready-to-Fly Total54.1 – 78.4 lbs
ConstructionMaterials6061 T6 / 7075 T6 Aluminum, Grade 5 Titanium, Carbon Fiber Spars
Propeller140 cm Carbon Fiber (Bi-blade or Tri-blade)
NettingDyneema (5x stronger than Steel)
HardwareMotorOpenPPG v2.5 25 kW high-efficiency brushless motor
Motor ControllerField-Oriented Control (FOC) High-powered, weatherproof, CanBus controlled
Throttle ControllerBuilt-in altimeter, haptic feedback, EICAS
Battery PackCustom designed for paramotors with built-in Bluetooth BMS and CanBus for communications. Using high energy density MNC cells.
WarrantyCoverage12 months - 300 hours
Performance Characteristics
Thrust & Power
  • Maximum Thrust: 160 lbs (adjustable via controller)
  • Peak Power Output: 20 kW continuous
  • Power System: Brushless motor with FOC control
  • Efficiency: Industry-leading power-to-weight ratio
Flight Time
Flight duration varies based on:
  • Battery capacity (2.6 kWh or 4.8 kWh)
  • Pilot weight and gear
  • Flying style and power settings
  • Environmental conditions
2.6 kWh Battery: 20-40 minutes typical 4.8 kWh Battery: 55-80 minutes typical
Weight & Balance
  • Frame Only: 29 lbs
  • Small Battery (2.6 kWh): 25.8 lbs
  • Large Battery (4.8 kWh): 49.0 lbs
  • Total RTF Weight: 54.1 lbs (small battery) to 78.4 lbs (large battery)
Construction & Materials
Frame
  • Primary Material: 6061 T6 Aluminum
  • Structural Components: 7075 T6 Aluminum
  • Fasteners: Grade 5 Titanium
  • Spars: Carbon Fiber
  • Netting: Dyneema (5x stronger than steel)
Propeller
  • Diameter: 140 cm
  • Material: Carbon Fiber
  • Options: Bi-blade or Tri-blade configurations
  • Quick Release: Tool-free hub system
Electrical System
Motor
  • Type: Custom OpenPPG v2.5 brushless outrunner
  • Power Rating: 25 kW continuous
  • Efficiency: High-efficiency design
  • Cooling: Integrated airflow cooling
Motor Controller (ESC)
  • Control Method: Field-Oriented Control (FOC)
  • Weather Protection: Weatherproof design
  • Communication: CanBus controlled
  • Safety Features: Multiple redundant protections
Hand Controller
  • Display: Color LCD with real-time telemetry
  • Features:
    • Built-in altimeter
    • Haptic feedback
    • EICAS (Engine Indicating and Crew Alerting System)
    • GPS tracking
    • Bluetooth connectivity
Battery Pack
  • Chemistry: High energy density MNC cells
  • Management: Built-in Bluetooth BMS
  • Communication: CanBus integration
  • Capacities: 2.6 kWh or 4.8 kWh options
  • Design: Custom paramotor-specific packaging
Operating Conditions
Temperature Range
  • Standard Operation: -10°C to 40°C
  • Storage: 10°C to 25°C recommended
  • Charging: Follow manufacturer guidelines
Environmental Considerations
  • Weatherproof motor controller
  • Sealed battery enclosure
  • Protected electronics
  • Cold weather capability (see After-Flight Care)
Warranty
  • Duration: 12 months or 300 hours of operation (whichever comes first)
  • Coverage: Comprehensive parts and labor
  • Details: See Warranty Information
