Parts Identification
Parts Identification Legend
This section helps you identify all the components of your SP140 v2.5 system.
Frame Parts
Frame Parts Overview
ComponentDescription
Center FrameMain structural hub
Center Frame LegsLower support structure
Frame Hoop SectionProtective cage segments
Hoop ConnectorNumbered connectors (0-6)
Center Frame ClampSecures frame assembly
Carbon Fiber SparLightweight structural rods
Leg ClampSecures legs to frame
Goose Neck BarTorque compensation bars
Netting RodSupports protective netting
NettingDyneema safety netting
Center Frame ConnectorABS connection pieces
HarnessPilot support system
Full Assembly View
Power System Components
Motor Assembly
Motor Components
MotorOpenPPG v2.5 25kW brushless motor
Motor Mount PlateSecures motor to frame
Prop PlatePropeller mounting interface
Prop AdapterConnects prop to motor shaft
Electronics
Electronics Components
Motor ControllerESC (Electronic Speed Controller)
Hand ControllerThrottle and display unit
BMS Data PlugBattery management system connection
Main Power ConnectorHigh-current battery connection
Battery System
Battery Pack
Battery Pack2.6 kWh or 4.8 kWh options
Battery StandoffsMounting hardware
Main Power SwitchOn/off control
BMS PortBattery management interface
Propeller
Propeller Assembly
Quick Release Prop HubTool-free removal system
Propeller140cm carbon fiber (bi-blade or tri-blade)
Prop BoltsSecure prop to hub
Charging System
Charger
ChargerAC to DC battery charger
Charge PortBattery charging connection
Status IndicatorsLED charging status display
Component Locations
Front View
Front View
From the front (prop side), you can identify:
  • Motor at center
  • Hoop connectors numbered 0-6 (clockwise from bottom left)
  • Carbon fiber spars
  • Protective netting
Side View
Side View
From the side, you can see:
  • Goose neck bars
  • Center frame legs
  • Battery mounting position
  • Harness attachment points
Rear View
Rear View
From the back (pilot view), you can identify:
  • Hand controller position
  • Harness straps
  • Battery pack location
  • Frame leg assembly
Power System Layout
Power Pack
The power system consists of:
  1. Motor - Mounted at the front on the motor mount plate
  2. ESC - Mounted below the motor
  3. Battery - Slides into frame from bottom
  4. Hand Controller - Connects via cable to ESC
  5. BMS Connection - Data cable from battery to ESC
Important Identification Notes
  • Hoop Connectors: Numbered 0-6, must be installed in correct order
  • CF Spars: Two shorter spars for bottom positions
  • Battery Orientation: Note “THIS SIDE UP” marking
  • Propeller Direction: Check rotation arrow on prop
Parts List Verification
When unboxing, verify you have received:
Frame Components:
  • Center frame assembly
  • 2x Center frame legs
  • 6x Frame hoop sections
  • 7x Hoop connectors (numbered 0-6)
  • 6x Carbon fiber spars (4 long, 2 short)
  • Netting with rods
  • 2x Goose neck bars
  • Harness
Power System:
  • Motor with mount plate
  • Motor controller (ESC)
  • Hand controller
  • Battery pack (2.6 or 4.8 kWh)
  • Charger
  • Propeller with quick-release hub
  • All mounting hardware
Hardware & Tools:
  • Allen keys
  • Socket wrench
  • Titanium bolts and lock nuts
  • Instruction manual
If any parts are missing or damaged, contact with your order details.
